Engine Buildup questions
Old Aug 25, 2004 | 05:22 PM
  #16
buzz12586's Avatar
Re: Engine Buildup questions
Are you sure the knock sensor is the same?? I have had a bunch of people tell me I have to switch it.
Old Aug 26, 2004 | 12:28 AM
  #17
aklim's Avatar
If you are goint that route, why not just go with a Holley Stealth Ram setup with all the pieces in it? That includes your fuel pump, KS, TPS, harness, etc
Old Aug 26, 2004 | 01:35 PM
  #18
buzz12586's Avatar
How much does it cost for that setup?
Old Aug 26, 2004 | 03:50 PM
  #19
tealman92's Avatar
Let me help you out.
I built a 345hp tbi motor in my old car.
What I did:
I used a 350 tpi block (L98) from a 1989 iroc.You want to use a 88 or newer block because they are roller blocks
Ported heads remachined the valve spring purches to fit high lift springs
Manley stainless valves
Lt4 hot cam
1.6 roller rockers
trw pistons I had 9:8to1 compression good enough to still use 89 sometimes
bored 30 over
slp headers
454 tbi unit with matched injectors from turbo city
tpi fuel pump form the auto parts store only 65 bucks
edlebrock intake (had to have the tbi holes bored to 2" holes to fit the 2" holes of the 454 tbi unit)
Injector spacer
custom burnt prom with just the spark curve and fuel messed with
I set my timing at 4 degrees advanced
350 knock sensor
My car passed california emissions perfectly
Sorry to say my car was totaled by a drunk driver while it was parked out front. It ran a 13.74 @100 with a 1.8 60'
The motor now with a tpi system on it sits in my 1989 trans am with a 50 shot of Nos on it. It ran a 12.6 @108 so she is a great runner hope that helps you out
Old Aug 26, 2004 | 05:53 PM
  #20
Ben91RS's Avatar
Wow! I'm pretty impressed with that TBI set-up. Most people don't get that far. Do you mind if I ask how your HP was measured (flywheel, at the wheels, or desktop dyno)?
Old Aug 26, 2004 | 11:13 PM
  #21
buzz12586's Avatar
Thats awesome man. I am looking for a list just like that. The biggest part of that is passing emissions and I see that you did. High 13's sound great as well. Thanks a lot!!
Old Aug 26, 2004 | 11:30 PM
  #22
fast81's Avatar
what year 350's are u guys geeting the knock sensor from. any specific?
Old Aug 27, 2004 | 12:10 AM
  #23
buzz12586's Avatar
Yea thats a good question. So I need an 88 or newer block in order for it to be roller?
Old Aug 27, 2004 | 12:18 AM
  #24
tealman92's Avatar
that was rwhp done on a dyno it pulled 344.6 hp with 391 torque. I used a 1992 knock sensor since my car was a 1992 rs. Yes a 88 or newer block from a f-body is roller but from a truck its a roller block but a flat tappet cam was used instead dont ask me why gm did this
Old Aug 27, 2004 | 11:36 AM
  #25
buzz12586's Avatar
Now if you have a 350 block with a 400 crank that makes a 383 right? So what does it become if you have the 350 block bored out .030"? .040" over.
Old Aug 27, 2004 | 12:16 PM
  #26
raul.garcia's Avatar
My 88' IROC TPI has a Motown 350/4-bolt main race block bored 0.60" over (max for factory other than race is 0.030" over) has 3.75" Scat crank & 6.00" conrods with SRP forged alum. -16cc dished flat top pistons x 1.25" piston height, zero deck height, 0.041" x 4.155" bore head gaskets, GMPP fast burn alum 62c heads which calculates to 388/6.4Liter.
Old Aug 28, 2004 | 01:35 AM
  #27
buzz12586's Avatar
Yea but that doesn't answer my question. lol. What would it be if it was bored 30 over
Old Aug 28, 2004 | 02:03 AM
  #28
97WS6SCharged's Avatar
A 355.
Old Aug 28, 2004 | 01:16 PM
  #29
aklim's Avatar
http://stealthram.com/costtoswap.html
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Jan 11, 2015 03:47 PM
cmdeshon
Dec 27, 2014 10:06 AM
squirrels
Jul 13, 2002 01:58 AM
