Emissions question
Old Aug 12, 2003 | 05:05 PM
GWHayduke's Avatar
Emissions question
I'm getting ready for my Smog Referee inspection and I can't figure out where to route the "Air Inlet" on the charcoal canister. I tried venting it to the atmosphere, but it causes a vacuum leak unless it is sealed shut. Where is this routed from the factory? Any help is appreciated. Thanks in advance.
-Blake
P.S. The motor is a 1991 TPI 350 from a Camaro.
Old Aug 13, 2003 | 02:19 PM
GWHayduke's Avatar
Nobody knows? Can anyone just look under their hood real quick?
Old Aug 13, 2003 | 05:35 PM
92BLKL98's Avatar
GWHayduke,
Just looked at my '92, one vac line from the rt. side port of the throttle body, one vac line from the fuel tank with a vac operated shut off valve (one line to the tank, one line to the canisterand another small control line to the top of the valve) in line. These lines attach to the purge solenoid (on top of the canister) . Then the air vent to atmosphere. If you have a vac leak apparently your canister purge solenoid is stuck open. Do you have a code set?
Old Aug 14, 2003 | 01:34 AM
GWHayduke's Avatar
It didn't set any codes and the solenoid checked out ok based on the factory diagnostic chart. When I pull the cap off of the air inlet tube, I get a loud hissing/whistle and a really erratic idle. I'll go scan for codes again but thanks for the input.
-Blake
kksi
Mar 21, 2015 09:03 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
Jason Short
Jan 19, 2015 06:34 PM
