An easy question for you lot!.
Old Mar 3, 2004 | 02:43 AM
Brit Iroc's Avatar
Can you tell me how an aftermarket electrical fuel pressure gauge works and is wired in please. Thanks.
Old Mar 3, 2004 | 08:37 AM
trackbird's Avatar
Typically, you ground one side of the sending unit, run 12v to the gauge and then run a lead from the gauge to the sending unit (not the grounded side).
What type of gauge are you using or did you just want general info?
Cheers!!!
Old Mar 3, 2004 | 12:12 PM
Brit Iroc's Avatar
ok. Sorry if I'm being a bit slow here but I take it you get a sender unit with the gauge, so how does that sender unit read the fuel pressure?. Where does that connect to?.
No, have not got one ( I have got one that screws into the test port on the fuel rail which I use). Just something else on the ' to do' list . Thanks.
Old Mar 3, 2004 | 01:36 PM
Marc 85Z28's Avatar
How does it work? Simple. The sender has a small orifice in which the fuel is allowed to enter. There is a small diaphragm that the fuel pushes against. The sender then then sends the electrical resistance set by the diaphragm position. The gauge interprets the resistance as a certain pressure.
Where does it connect? For a fuel injected engine like yours you can use the schraeder valve on the fuel rail. Some put it at the pressure regulator, and others tap into the fuel line itself. Where you put it is up to the design.
Old Mar 3, 2004 | 01:51 PM
Zepher's Avatar
Well, the unit I have is 3 pieces.
You have the gauge, the sender and a box that goes between the sender and the gauge.
Sender sends a signal to the box, box converts the signal for the gauge and the gauge displays the psi.
Old Mar 3, 2004 | 02:08 PM
Brit Iroc's Avatar
Got it. Thanks all.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Hurin
Dec 13, 2014 07:38 PM
pologreen97z
Dec 2, 2014 10:42 AM
