Does LT1 throttle body work on an L98 motor?
Old Jul 22, 2006 | 11:01 AM
96WhiteZ28's Avatar
Old Jul 22, 2006 | 01:58 PM
87DJP2001's Avatar
Re: Does LT1 throttle body work on an L98 motor?
No.........
Old Jul 22, 2006 | 03:43 PM
91Z-28's Avatar
Originally Posted by 87DJP2001
No.........
Maybe not with a stock L98 intake, but it can be used. For instance with the HSR it is recommended that you either use the LT1 TB or a 58mm TB. My car has an LT1 TB on it right now.
Old Jul 23, 2006 | 05:00 AM
Sleeper_Z's Avatar
How are you using an LT1 t-body when all the connections and sensors are different? AND do you know what a TPI t-body and an LT1 t-body have the exact same bore size? Just thought you should know.
Jeremy
Old Jul 23, 2006 | 10:26 AM
Dave89IROC's Avatar
Jeremy
change the connectors, and yes, it will work(if you use a 93 T/B, only need to change the TPS connector)
oldschool
Feb 9, 2016 09:21 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 11:01 PM
