Do they make cold air intakes for 3rd gens?
Old Nov 19, 2004 | 03:30 PM
  #16
klumb15's Avatar
Re: Do they make cold air intakes for 3rd gens?
yea i agree, that does look quite restrictive yet, probably better than stock tho....
Old Nov 19, 2004 | 06:29 PM
  #17
aklim's Avatar
Originally Posted by 91 Camaro RS
Is this what you're talking about? It says that only fits TPI engines.
My bad. I thought you were working with a 350 TPI
Old Nov 19, 2004 | 06:49 PM
  #18
91 Camaro RS's Avatar
I wish I was, but there is no way in hell I could afford the gas for one.
Old Nov 19, 2004 | 07:35 PM
  #19
aklim's Avatar
I got about 21 hwy and 16 city with my 383
Old Nov 20, 2004 | 12:03 AM
  #20
Zepher's Avatar
You can put a K&N Cone filter at the end of your intake, basically replace your air canister.
I'll get pics of my setups as soon as I get on the other computer.
Here is the Dual SLP installed on my 86 Trans Am,
This is the K&N on my 88 Formula,
Old Nov 20, 2004 | 12:05 AM
  #21
Can you also give me the model number?
Old Nov 20, 2004 | 12:15 AM
  #22
Zepher's Avatar
I don't think I have a model number for the K&N, I bought it about 4 years ago to use on my 86, then I bought the SLP unit. I might have the box in the garage, I'll check tomorrow.
It is an 8x4x3. I think I paid $45 for it from Jegs.
I also have this custom 4" air intake that a friend made for his 90 Formula, I traded a rear end for it.
here it is installed on my 86,
Old Nov 20, 2004 | 12:40 AM
  #23
The 3" filtes where what I was just looking at. I'll go measure the air tube tomarrow and see how big if a filter I can stick in there. The air tube probably is big enough for a v6, but the filter canister is very restrictive. This is the one I'm looking at: http://kandn.com/images/l/RU-2820.jpg
Old Nov 20, 2004 | 01:28 PM
  #24
I just went and measured, my intake tube is 4" at the canister. If I replace the canister with a K&N cone filter, what do I do with the oxygen sensor?
Old Nov 22, 2004 | 08:06 AM
  #25
Anyone know?
Old Nov 22, 2004 | 01:07 PM
  #26
Zepher's Avatar
Drill a hole into the air tube and put it in there. That sesnor is called the Air Intake Temp sensor.
Old Nov 22, 2004 | 01:30 PM
  #27
Aiight, that's what I thought. I'll have to take the intake completely off to clean out the tube of plastic shavings then. I'll look into the intake setup that transxtreme has, and I'll also look into the K&N cone filter. Thanks for all the suggestions.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
slothgrant
Aug 22, 2002 03:01 PM
ezcheeze15
Aug 8, 2002 12:27 AM
