do I need the O2 sensor thats in the manifold
Old Dec 1, 2003 | 02:51 PM
kbog54's Avatar
Question do I need the O2 sensor thats in the manifold
Do I need to keep the oxygen sensor that is in the bottom of the manifold, where the exhaust pipes exit? What will happen if I just unplug it?
thanks
Old Dec 1, 2003 | 03:28 PM
Marc 85Z28's Avatar
Are you still running the factory computer controls? If so removing it is probably the worst possible thing you could do as the O2 sensor is one of the highest priority sensors in the system. The car will run horrible!
Removed the computer controls? Then the O2 is no longer needed. Disconnecting it will not harm a thing. However, remember, it does provide an obstruction in the exhaust. You could remove it completely and replace it with a pipe plug from your local hardware store.
Old Dec 2, 2003 | 05:59 PM
97WS6SCharged's Avatar
Don't remove the O2 unless you're going to a carb. The computer needs the O2 readings to adjust injector pulse width so the car will stay close to stoich (14.7:1 AFR). If it doesn't get any readings from this sensor it will default to a table that is similar to the start up table and run the car quite a bit richer that it should be.
mightymouse383
Jul 20, 2016 07:34 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 8, 2002 12:36 AM
Fusion93Z
Jul 29, 2002 06:13 PM
