Do I need charcoal canistor???
Old Jul 15, 2003 | 11:30 AM
shanebang76's Avatar
Looking for somewhere to mount MSD ignition box and heard someone say that they removed thier charcoal canistor. If I have already had prom programmed with no smog or EGR, can I remove this? Will this give me trouble with gas tank vapors or fumes??? This looks like a good place to mount MSD box being away from direct heat over near fenderwell. HELP PLEASE!!!!!
Old Jul 15, 2003 | 12:05 PM
angel71rs's Avatar
I removed mine on my 89 formula 350 so I could turn air filter housing sideways. Before housing inlet was pointed right at radiator support with less than 1/4" clearance. But now Charcoal cannister was in the way, so out it comes. Plugged vacuum line to engine.
But I noticed immediately that pressure was building in gas tank. So I connected line to tank directly to vacuum line with a .030" restriction in it. otherwise it would be a huge vacuum leak. Problem solved.
I did this all in a hidden area, so when I go in for emissions inspection, the guy checking it has never noticed anything was up.
Old Jul 15, 2003 | 12:19 PM
82355's Avatar
No need for the charcoal cannister but leave that line to the fuel tank unplugged.
Martin
Old Jul 15, 2003 | 12:51 PM
phoenix916's Avatar
What about the round canister thing down underneath The Vacuum canister area (looks like a little plastic bowling ball with one vacuum line)? I moved all that stuff to make my CAI and if I can just yank it that would be better.
Brett
Henson071
Dec 30, 2015 09:55 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
