Distributer Gear
Old Feb 17, 2005 | 06:11 PM
irocz383's Avatar
Distributer Gear
So I'm getting my motor rebuilt and noticed my distributer gear is worn.
So now I have two options. Either the Bronze gear or the new composite gear from Comp Cams.
The car is a daily driver but it only sees the road maybe 3 days out of the year... Maybe 5-10,000 km's a year.
Heres the link on the two gears I have to choose from. Price difference is about $100.
Old Feb 19, 2005 | 05:47 PM
90rocz's Avatar
Re: Distributer Gear
"Bronze" gears are usaully only used with "steel"cams, b/c an iron gear will destroy the teeth on the cam. An cast iron gear should be used on stock type iron cams. You want the wear on the cheap to replace distributor gear not the expensive cam.
Old Feb 19, 2005 | 07:55 PM
85_305's Avatar
If your rebuilding the engine, why are you not putting in a better ignition and a new distributor? Just wondering. My engine had 200k on it, and the distributor was BEYOND needing a new one, lol.
Old Feb 19, 2005 | 08:02 PM
irocz383's Avatar
It is a new distributor. I bought a MSD Billet Aluminum piece. They come with a cast iron gear though and I totally overlooked the fact that the cam gear wouldn't mate right with the distributor gear. Thats why its worn out in less than 1000 km's.
Motor was finished last year but I had some cylinder wall glazing and burning oil problems so its getting a refresh right now.
Old Feb 19, 2005 | 11:09 PM
85_305's Avatar
^Ahh.. ok. I was thinking, judging by your mods and your car, you COULDN'T be an idiot.. so why would you re-use your freaking distributor, lol. It's all good though
Old Feb 21, 2005 | 12:01 AM
90rocz's Avatar
Can't say about the wear of the composite, never used one, but I like the Bronze, I've had good luck with them in the past.
Old Feb 21, 2005 | 07:19 AM
89385formula's Avatar
I was also interested in in that composite comp distributor gear, I called about it and they told me you couldn't use it in a engine w/ normal oiling system. I don't know why, but I guess I will be running a bronze gear after all.
Old Feb 21, 2005 | 10:49 PM
90rocz's Avatar
Improved Bronze gear @ JEGS for $35.00 bro...!
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
ChrisFrez
Mar 22, 2015 09:12 AM
