disconnecting fuel return lines and fuel inlet lines on the throttle bodies
Old Jun 24, 2012 | 05:43 PM
Lichowid's Avatar
I have a 1983 crossfire camaro trying to figure out how to disconnect the fuel inlet line and fuel return lines connected to the throttle bodies, last time I tried to turn them I ended up bending a line slightly
Old Jun 24, 2012 | 06:00 PM
Dave89IROC's Avatar
If I recall, you need to hold the fitting on the throttle body, and use a line wrench on the tube fitting, same as a newer tbi unit, but a picture would help
Old Jun 24, 2012 | 06:20 PM
Lichowid's Avatar
Re: disconnecting fuel return lines and fuel inlet lines on the throttle bodies
it said to disconnect in the hayes manual but yea no describtion to how I was thinking some kind of penatrating oil after all this car is older than me
Old Jun 24, 2012 | 07:52 PM
#2's Avatar
Try posting in one of the tech sections. This is the off-topic area.
Old Jun 24, 2012 | 08:42 PM
If you don't start posting these questions in the tech forums, where they belong, your account will be closed.
Moving.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
David Dorris
Jan 17, 2015 08:10 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Jul 4, 2005 05:00 PM
