difference in sound from rod knock and detonation?
Old Nov 9, 2003 | 10:38 PM
kevin 2.8's Avatar
when my winter beater (lincoln tc 1986 5.0) idles with the hood up i hear a sound that im not sure if its detonation or a rod knocking. i added a can of engine restor to see if that lubes it to reduce the sound...
how do i know which prob it is
rod knock is a worn bearing, what is detonation and how do you fix it? what doe they sound like?
Old Nov 10, 2003 | 01:51 AM
aklim's Avatar
Run the tank dry and put in a gallon of race gas or some gas with really high octane. If it knocks, that is not detonation. Drain the oil and put in 40 wt oil and a can of STP. If it quietens down, you have rod knock.
Old Nov 10, 2003 | 10:57 AM
KnightRider350's Avatar
How do you fix rod knock permanently, besides running heavier oil? I own a thirdgen. I'm sure I'm going to need to know this.
And what's the sound difference between a rod knock and lifter noise.
Thanks.
Old Nov 10, 2003 | 11:03 AM
12Second3rdgen's Avatar
Thanks.
Replace the motor or rebuild it.
Old Nov 10, 2003 | 12:27 PM
aklim's Avatar
Thanks.
Easy, R&R engine and rebuild it.
difference
Old Nov 11, 2003 | 03:03 PM
JJEXP's Avatar
or just change the rod bearings
Old Nov 11, 2003 | 04:59 PM
aklim's Avatar
If I am that far, I might as well change everything before I have to do it again. Cheaper to do it all once than to do it again.
Old Nov 11, 2003 | 07:16 PM
JJEXP's Avatar
not really. You don't even have to pull out the engine or disconnect the tranny to change the rod bearings. Just jack up the engine a few inches and drop the oil pan
Old Nov 11, 2003 | 09:10 PM
aklim's Avatar
You sure that the cam bearings and the cylinder bores don't need to be refreshed? I mean, if one set are worn out, could the others be that far behind?
OK. For the winter beater, I would just change the rod bearings like mentioned but if it was the other question where you are looking to fix up the car, I would refresh the engine if I was keeping it and it wasn't a winter beater.
Old Nov 11, 2003 | 09:12 PM
aklim's Avatar
Don't forget the oil pump. Get a high volume but not high pressure one.
karnykamaro
Feb 2, 2015 01:37 PM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
Lions3
Aug 27, 2002 01:33 PM
