Detonation?
Old Aug 14, 2003 | 09:13 PM
DrDUKE's Avatar
Detonation?
I think i might be have some detonation at low rpms due to some symptoms ive been reading on some forums.
What is detonatoin?
How should i go about fixing it?
Old Aug 14, 2003 | 11:49 PM
aklim's Avatar
What are the symptoms you observed? Have you hooked up a scantool to see if it is detonation or whether it is a loose bolt? A way to fix it is to get a colder plug and or higher octane gas. First figure out if you are having detonation or not.
Old Aug 15, 2003 | 01:07 PM
OneSickS10's Avatar
Re: Detonation?
What is detonatoin?
I would start with higher octane gas. If you have to change heat ranges on the plug something is wrong, if your vehicle is factory fuel injected with minor or no mods you shouldn't have to mess with heat ranges. Something is wrong somewhere else, as you know ... all those sensors and wires are there for a reason as ugly as they are to look at, they make it possible to drive in any weather condition without tuning the car.
Try a tune up, cap,rotor,wires,plugs,pcv,air,fuel.. maybe even a new pickup coil in the distr. and some fuel injection cleaner.
Old Aug 15, 2003 | 02:08 PM
DrDUKE's Avatar
Well, all the cap rotor wire etc are new. The reason i believe i have detonation is the rocks in a can sound comming from cat area of the exhaust. Everything was snug in the area. I also noticed the rich smell along with the semi erratic idle it would all make sence.
Old Aug 15, 2003 | 09:24 PM
aklim's Avatar
If it were detonating, would it be running rich? I would think it would more likely be lean. Get the scantool and we can see what is going on. If it is really detonation, I would like to see that the ECM is reading the O2 sensor as lean.
Old Aug 15, 2003 | 10:28 PM
OneSickS10's Avatar
Pull a plug and see what it looks like... if its black, its fouled out and running too rich.. or possibly a bad plug. If it has a white tip, and your not burning antifreeze, then your running too lean. Then from there you will know if its a fuel / spark problem or bad sensor.
Old Aug 16, 2003 | 01:32 AM
AutoRoc's Avatar
dghdf
If the plug has pieces of aluminum on it or looks like it just went thru a nuclear disaster...That's a possible pre-detonation problem sir Don't ask...hahahaha
n2oTransAmLT1
May 14, 2003 08:02 PM
az1gplus
Feb 7, 2003 01:38 PM
rncotton
Sep 8, 2002 08:48 PM
CLEAN
Aug 20, 2002 12:45 AM
tbyrne
Aug 16, 2002 01:12 PM
