Detonation?
What are the symptoms you observed? Have you hooked up a scantool to see if it is detonation or whether it is a loose bolt? A way to fix it is to get a colder plug and or higher octane gas. First figure out if you are having detonation or not.
Re: Detonation?
Originally posted by DrDUKE
I think i might be have some detonation at low rpms due to some symptoms ive been reading on some forums.
What is detonatoin?
How should i go about fixing it?
What is detonatoin?
as ugly as they are to look at, they make it possible to drive in any weather condition without tuning the car.Try a tune up, cap,rotor,wires,plugs,pcv,air,fuel.. maybe even a new pickup coil in the distr. and some fuel injection cleaner.
Well, all the cap rotor wire etc are new. The reason i believe i have detonation is the rocks in a can sound comming from cat area of the exhaust. Everything was snug in the area. I also noticed the rich smell along with the semi erratic idle it would all make sence.
If it were detonating, would it be running rich? I would think it would more likely be lean. Get the scantool and we can see what is going on. If it is really detonation, I would like to see that the ECM is reading the O2 sensor as lean.
n2oTransAmLT1
May 14, 2003 08:02 PM
Don't ask...hahahaha
