Deleting EGR
Old Mar 28, 2005 | 05:42 PM
  #16
cc89formula's Avatar
Re: Deleting EGR
I think Im just gonna make mine, but if you can find them cheap let me know
Old Mar 28, 2005 | 11:26 PM
  #17
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: Deleting EGR
Originally Posted by anthony714
why do you wanna rip egr off..first you aint going to see much of an increase if any..secongd it shouldnt set a light off cause an egr if i recall is only an output signal and that shouldnt set off light unless you unplug the electricall conector..just remove the egr valve or just unhook it and plug the vacuum line..the comp dont know if the vacuum line is unhooked as long as its plugged..what exactly are you looking to do?make horsepower?lighten car?go fasteR?????
Yes, the computer does know if the EGR isnt working. The EGR is the only smog device the computer keeps track of. On MAF cars, there is a temp sensor in the EGR valve. When the valve opens, it will get hotter. On MAP cars, the computer checks for a change in the MAP when the EGR opens.
Old Mar 29, 2005 | 09:47 AM
  #18
LoudmouthSS's Avatar
Re: Deleting EGR
hmm...ok so Ill just be staring at an SES light..no big deal. I dont like my hypertech chip anyway, im gunna go to diablo tuning around here and get them to make me a custom chip, so that'll solve my SES problem
Old Mar 31, 2005 | 11:31 PM
  #19
billyhoss's Avatar
Re: Deleting EGR
iam going to remove my egr too and was wondering if i can remove that whole setup just under the coil and just plug the vac line that goes to the tb, iam thinking that when the ecm tells the egr to open it gets its vacuum pressure from the connection at the tb once that swtich opens up under the coil? anyone help me out? thanx
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
