Corvette intake manifold
Old Aug 17, 2003 | 09:53 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
does coolant go through the late TPI intake manifold?
Old Aug 17, 2003 | 10:28 AM
aklim's Avatar
It should. My intake manifold has a gasket with a few extra holes in it for that. When the gasket blew once, there was coolant all over.
I have the SR intake manifold and that is what they use for the vettes, I believe.
Old Aug 17, 2003 | 10:53 AM
TheGreatJ's Avatar
Only the base manifold....the runners and plenum don't pass any coolant but the throttlebody does if you haven't bypassed it.
Old Aug 17, 2003 | 09:44 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
I think on the stock TPI manifold, there is no coolant in the rear, but on the aftermarket ones, there is. I might be wrong.
Old Aug 18, 2003 | 07:12 AM
Jim85IROC's Avatar
There's coolant front and rear on both stock and aftermarket intakes.
Old Aug 18, 2003 | 07:42 PM
Kevin91Z's Avatar
I just went and looked at a stock '87 intake I have, plus my old '91 stock intake, and neither one has coolant passages in the rear. I know my TPIS intake has it. I cant speak for stock 85-86 intakes nor for Corvette stock ones.
Old Aug 18, 2003 | 09:05 PM
Jim85IROC's Avatar
I stand corrected. I just looked at my stock 85 intake, and there is no coolant passage in back. After examining the intake, it's not likely that ANY TPI intake has them... the runners are in the way on the driver side.
Old Aug 21, 2003 | 05:09 AM
Matt_Ky's Avatar
Speaking of 85-86 TPI intake manifolds, anybody have one for sale? I need and '85-86 to go on a 355 '72 block w/ pre '87 heads.
Thanks!
Chris
Old Aug 21, 2003 | 04:02 PM
Marc 85Z28's Avatar
I've got one from an 85. Came off a clean 85 IROC. I've got the rest of the TPI setup (minus harness and a few sensors) to go with it if you want it - dirt cheap. Make an offer - trades welcome too...
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
