Correcting Speedometer
Old Oct 22, 2007 | 10:56 AM
splinter_cell's Avatar
My dad is going to get some 4th gen rims for his 92 Z. What will he need to do to correct the speedometer?
Old Oct 22, 2007 | 03:50 PM
1987IROC350's Avatar
There is a gear in the transmission that will have to be changed if its a Z28. If it is a 3rd gen Trans Am it could have an electric speedometer.
Old Oct 22, 2007 | 11:03 PM
Yeah it's a Z28 and he has an electronic speedometer.
Old Oct 23, 2007 | 06:26 AM
Z28SORR's Avatar
Don't necessarily have to change anything! It depends on the TIRE diameter. If you maintain the same overall dia., you don't need to change the gear.
Old Oct 23, 2007 | 02:29 PM
Marc 85Z28's Avatar
You have to change the gears, even on the electric speedometer cars. Unless you plan to go to a 30+ inch tire or a 20 inch tire, a tire swap won't cut it.
http://www.thirdgen.org/calibrate-speedometer
http://www.thirdgen.org/speedogear
Old Oct 25, 2007 | 09:21 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
This answer is correct.
Aaront810
Aug 29, 2020 09:34 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
RubyRedIrocZ
Sep 10, 2015 01:48 PM
