Cooling Problems
Old Jun 16, 2006 | 09:31 PM
  #16
Black305RS's Avatar
Re: Cooling Problems
also how many prongs areee on the switch it seems to only have 2 in the picture.
from the picture i would have to say that the switch will not work. you will need at least a 3 prong switch.
Old Jun 16, 2006 | 11:28 PM
  #17
Black305RS's Avatar
i also forgot to mention that you need a fuse on the hotside going to the relay. i used a 30 amp fuse.
Old Jun 18, 2006 | 12:08 PM
  #18
DE34E's Avatar
Due to my overheating and taking it to several dealers, I decided to try removing the radiator and clean debris between radiator and cowling.
Old Jun 19, 2006 | 12:43 AM
  #19
88 irocz 350 5-spd's Avatar
OK, so i finally got my fan going by just hooking up a switch. so now i have complete control over it and the ecm has none, but when i took it out for a drive, it still hovers around 220 which is still way too hot. it will usually be around 200 when im driving a maybe a little lower when i have the fan on or just as hot as without it. im not sure what to do now? i have a 160 thermo in it but that doesn't seem to make any difference, it will still easily overheat im sure and is still running too hot. what should i try next???
Old Jun 19, 2006 | 01:22 PM
  #20
Black305RS's Avatar
mine hovers around that temp as well. the only time ive seen one of my f-body's at a temp lower than that was my 91 rs and i had put a brond new aluminum radiator in it and did a coolant flush.
Old Jun 19, 2006 | 05:15 PM
  #21
i was thinkin about doin the same as well. ill do a coolant flush as soon as possible but where did you get your radiator at? ive looked around and they aren't exactly cheap. i was also thinkin about a new water pump as well, or do those really crap out that easy?
Old Jun 19, 2006 | 05:33 PM
  #22
Black305RS's Avatar
i got my radiator at auto zone for 99 bucks. you could also get one of the newer style radiators. its something like a 4 chamber or something like that. someone else would have to elaborate.
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
