Converting my 350 V belt system to serpentine system
Old Mar 8, 2006 | 01:19 PM
Night Rida''s Avatar
I am about to drop in my 72 el camino 350 engine into my 91 camaro...The 350 has a 4bbl edelbrock carb,edelbrock intake,headers,4 bolt main,cam,etc...My only question about this swap is will my serpentine belt system/brackets bolt up to my 350?All and any info will be greatly appreciated
Old Mar 8, 2006 | 04:22 PM
3liter914-6's Avatar
Re: Converting my 350 V belt system to serpentine system
It should bolt up just fine. The only two issues I can see with the swap, are the accessory bolt holes in the heads which changed in '68 so unless for some strange reason you have pre-68 heads you're fine on that front.
The other issue is waterpump length and rotation, and as long as you swap everything (incl. WP) from the '91 to the '72 you should be golden in that respect.
Good luck.
Old Mar 9, 2006 | 04:36 PM
krazzycowgirl's Avatar
Yeppers they have kits that are about 500 from summit that you can just buy to swap everything over. Thats what I am doing
Old Mar 9, 2006 | 04:37 PM
Old Mar 9, 2006 | 08:55 PM
well I am trying to do this on a budget so if my serp. system will fit,then i will just go about using my old stuff
linz
Oct 22, 2015 07:59 AM
grabbem88
Feb 23, 2015 09:41 PM
Omega9
Aug 14, 2002 07:55 PM
