Converting To 383 Need Ecm Help
Old Feb 16, 2008 | 12:31 PM
SS840's Avatar
Im Rebuiling My 88 Iroc Im Puting In A 383 And The Hsr Intake And Plenum Justwant To Know If I Will Be Able To Tune The Speed Dens Comp To Get It Running Right
Old Feb 17, 2008 | 06:46 AM
rskrause's Avatar
Moderator
Yes. Tunercat and a chip burnner, along with a chip adapter and you can tune away.
BTW: All Those Caps Are Annoying ;-)
Rich
Old Feb 17, 2008 | 11:37 AM
87zjeff's Avatar
are you going to be sing the 7730 speed density ecm or the factory one that came with your car? if you are converting to speed density using the 7730 ecm, you can get a module that can be wired to your ecm and do the tuning through the aldl connector just like the later pcms.
Old Feb 17, 2008 | 04:53 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
I'm using a 7730 computer and am able to tune my car just fine. But I also use the Moates Ostrich, which plugs into the computer and lets you make changes while the engine is running.
Old Feb 18, 2008 | 01:03 PM
SS840's Avatar
Ecm
I Will Be Using The 7730... So With That Moates Hows It Work? Do I Tune From The Aldl
Old Feb 18, 2008 | 08:18 PM
SS840's Avatar
Injectors
Hey I Was Also Wondering If The Factory Injector Driver Will Handle 30lbs Svo Injectors??
Old Feb 22, 2008 | 11:36 AM
onefastgta's Avatar
Yes, it will handle 30 lbs injectors.
Old Feb 22, 2008 | 11:40 PM
Kevin91Z's Avatar
The Moates plugs into the ECM like the stock chip does now, and then it plugs into the USB port of your laptop. You use TunerCAT or TunerPRO to modify the program based on what the computer wants. You need a scantool hooked up to the ALDL to know what fuel and timing settings to change to make the engine happy.
Old Feb 24, 2008 | 07:14 PM
11secgen's Avatar
id just get a $10 eeprom(the stock one isnt eraseable,so its a eprom) to swap out your chip with. also they have the chip burner on ebay for $15 and tunercats trial is free,you just need the defenition file for another $20 and youll be able to burn all the chips you want for under $50
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
4586
Dec 31, 2014 02:21 PM
