Code 12??
Old Nov 25, 2003 | 12:15 PM
Timberwolf's Avatar
Code 12??
No signal to the pcm
how is that posisble? the car runs and drives fine other than being a little rich.
What causes this problem?
Old Nov 25, 2003 | 02:14 PM
IROC-T's Avatar
Code 12 is all systems are good,for the rich part change your O2 sensor.
Old Nov 25, 2003 | 05:16 PM
Timberwolf's Avatar
Why would I have an SES light then if that's the only code?
Old Nov 25, 2003 | 08:00 PM
IROC-T's Avatar
Are you reading all of the codes? 12 will flash first and then you will get the next one ,and so forth until all codes are shown. Be sure you are holding the scan long enough to get all. If that IS the only code then I am stumped. It could be a stuck relay also.
Old Nov 25, 2003 | 08:17 PM
Timberwolf's Avatar
it just repeatedly flashes 12... no other codes...
Old Nov 25, 2003 | 10:40 PM
MasterEvilAce's Avatar
pretty sure that means everything is looking good...
with the car RUNNING, is the SES light on?
If so, then code 12 is probably there, for you
if not, then it's supposed to flash
12-12-12 <--- starts code sequence
any other codes
12-12-12 <---- ends codes
if the SES light is NOT on when the car is running, then your car is fine
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
