Chirping sound from valve covers
Old Dec 2, 2003 | 11:32 AM
Warlock4890's Avatar
I have a sound that sounds like a loose belt, but it only happens when I rev the engine, and when I'm under the hood it sounds like it is coming from the lifters or from around the valve cover area. I have checked the belts and they are tight. The oil only has about 1000 miles on it and I believe that it is 10W40. Anyone have any ideas?
Old Dec 2, 2003 | 11:55 AM
aklim's Avatar
See if the rockers are tight. If they are your lifters might be going away soon.
Old Dec 3, 2003 | 07:32 AM
So if my lifters are going I have to change the Cam at the same time correct? Around how much does a lifter and Cam set run? I saw one for around $450, but that sounds a little high.
Also are these hydrolic cams or are they roller?
Old Dec 3, 2003 | 09:10 AM
aklim's Avatar
I believe you have a roller cam. You could take the manifold off and change the lifters without touching the cam which is a whole different ballgame. The 16 lifters are held down by a spider like retainer.
Old Dec 6, 2003 | 05:43 PM
VeryBad's Avatar
Pull off the belt and rule that out first.
Gordon
WitchHunter Performance
Old Dec 6, 2003 | 08:08 PM
I finally got some time to get it into the Hobby shop here on base and pulled the belt. It was tight, but it was going bad. Once I replaced that, the sound went away. Thank God too, I really didn't want to dump that much money in a car I just got and still owe on. But the lifters still make a ticking sound, I believe that they just need adjusting.
Thanks for all your help!
HectorM52
Jul 30, 2017 11:46 AM
karnykamaro
Feb 2, 2015 01:37 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
