check engine light
Old Apr 14, 2009 | 11:55 AM
tgates's Avatar
check engine light
my 91 camaro 5.7, engine light comes on when i start it and will go away when it warms up. but after that it will come on and off randomly. the car runs like crap when its on, but when it goes off it acts like nothing is wrong. i thought it was my O2 sensor so i changed it but it didnt help. anyone know why it does this?
i have-
gutted air box
jet stange 2 chip
air foil
after market magnaflow cats with the AIR not hooked up.
cat back exhaust
Old Apr 14, 2009 | 11:58 AM
6SpdLT1Z's Avatar
You should be able to run a OBD-I scanner, shouldn't you?
Old Apr 14, 2009 | 12:00 PM
tgates's Avatar
idk i thought it was the flashing code stuff.
Old Apr 14, 2009 | 12:07 PM
6SpdLT1Z's Avatar
I believe they should have a OBD I port under the dash, though I'm not 100% sure as I've never owned a third gen.
Old Apr 14, 2009 | 12:09 PM
tgates's Avatar
ok. but does any know what might be causing it?
Old Apr 14, 2009 | 12:23 PM
6SpdLT1Z's Avatar
Well if it has a OBD-I port you can run a OBD-1 scanner and get a code/description of whats wrong with your car.
Old Apr 14, 2009 | 04:36 PM
Rice Killer87's Avatar
You can turn the key on and jump the top row, right 2 holes and it should flash code 12 3 times and then flash the SES light code 3 times.
Then report back with the code.
Old Apr 24, 2009 | 04:55 PM
Gtpguy's Avatar
If you use a metal paper clip in the top right holes of the port, with the car off, turn the key to on. The SES light will flash 1 beat...then 2 beats. That is code 12. It will do that 3 times. Then it will flash the first real code. Whatever it will be, again 3 times. Depending if you have more than one code, it will then reflash code 12 telling you that is all the codes.
It seriously takes less than a minute. I love obd1 for that, you don't need a scanner to see whats going on with the car.
Old Apr 24, 2009 | 05:02 PM
JakeRobb's Avatar
Super Moderator
Have you tried hooking the AIR back up?
Old Apr 27, 2009 | 08:49 AM
ws6transam's Avatar
The Paperclip scan is easier than anything you could ever do under the hood--- Easier than checking your air filter for bugs, even.
Get the flash code sequence, look it up on thirdgen.org and get back with us.
Old Apr 29, 2009 | 10:24 AM
teke184's Avatar
pull the chip....sounds like the "performance programming" is messing up some sensor signals.
Old Apr 29, 2009 | 12:17 PM
SupplySgt.'s Avatar
heck you can even use a staple to jump the ports. as long as it's long enough to reach and it's metal then you'll be able to pull the codes that way. If you get us the codes we'll have a much easier time pointing you in the right direction
Old Apr 30, 2009 | 05:21 AM
He pulled the code and got responses a while back:
https://www.camaroz28.com/forums/sho...d.php?t=682087
https://www.camaroz28.com/forums/sho...50#post5930750
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
