changing oil pan
Old Apr 25, 2007 | 12:57 AM
zoocop's Avatar
changing oil pan
What do I need to do to remove old oil pan and put new one on. Car is a 1984 z28, trying to do on driveway hopefully w/o having to remove or lift engine
Old Apr 25, 2007 | 12:57 PM
Anniversary-Z-man's Avatar
Depends on the pan you may need to at least lift the engine up. I am only familiar with the 350's so I can't be certain.
Old Apr 25, 2007 | 02:08 PM
confused327's Avatar
you need to lift the engine.
Old Apr 25, 2007 | 02:35 PM
Z28SORR's Avatar
Depends on your mods.
If stock, you'll have to remove the exhaust Y-pipe from the exhaust manifolds. You may have to pull the distributor cap, depending on how high you lift the engine. You may have to pull the starter to get at the bolts next to it. If it's an auto, you'll have to pull the converter cover and be careful of the trans. coolent lines. Can't think of anything else, except generally being careful of the hoses and wires when you raise the engine.
Old Apr 27, 2007 | 04:11 PM
onefastgta's Avatar
I have to pull the tranny back to pull the pan on mine, even with the dist cap off and motor mount bolts out with the motor jacked up as high as it can go.
Sometimes you can get the pan to clear the flexplate/flywheel, sometimes not.
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
