Carb and HEI recommendation for a 350 5 Speed Combo
Old Sep 11, 2012 | 04:57 PM
BLACK Z !'s Avatar
Hi, I currently have the electronic Q Jet on the car, I have a Gm 350 along with a 5 Speed, My other mods are in my Sig Below, Just wondering what carb is recommended, It is not a daily driver but I am looking for a good reliable carb,I am also looking for an HEI Dist to go along with it.
By Changing the Carb and Dist is there anything else I need to do? can I just take the Check engine bulb out and worry about it after this?
Old Sep 12, 2012 | 08:08 PM
quickchicken's Avatar
Re: Carb and HEI recommendation for a 350 5 Speed Combo
have you ever thought about stepping up to injection? with you ready to make an upgrade the FAST ez EFI would be a great move. self tuning, built in wide band, able to change setup when you build a bigger motor.
Old Sep 13, 2012 | 07:41 AM
BLACK Z !'s Avatar
What is the cost for a system like this?
Old Mar 1, 2013 | 07:53 PM
BLACK Z !'s Avatar
Spoke to Holley and they Recommended the 600 CFM Double Pumper, Or the 650 DP.
As far as DIST go Should I go in cap Coil ( HEI ) or Separate Coil/Dist?
Do I need a adjustable Vac advance or not?
Old Mar 4, 2013 | 08:55 PM
BLACK Z !'s Avatar
Well I ordered these today, hope I made a good choice.
Holley Performance Products 650 CFM Ultra Double Pumper™ Four Barrel Street/Strip Carburetor - Black™ 0-76650BK
MSD Pro-Billet HEI Distributors 8365 - SummitRacing.com
Old Apr 30, 2013 | 10:48 AM
Paul Huryk's Avatar
If your car runs well - no issue with the carb, leave it alone.
You can easily tune the carb for a larger motor with more power - it will support 500hp with the right fuel system.
Old Apr 30, 2013 | 06:07 PM
BLACK Z !'s Avatar
There are issues that is why I want to change it.
dfarr67
Apr 10, 2015 07:44 PM
draven666
Nov 26, 2014 07:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Omega9
Aug 14, 2002 07:55 PM
