Help with eng
Old May 1, 2013 | 08:47 PM
Gregdonna's Avatar
Help with eng
I'm looking to get some more power from my 5.7 TPI. What heads would you think would work the best on this and what cam. I like to keep the TPI just because it looks mean when you left up the hood. I'm having a new rear end installed and its a 410. Also what kind of chip should I install to help out with the tune.
Old May 1, 2013 | 08:59 PM
96m6lt1's Avatar
Re: Help with eng
Why 4.10s? That is far too much gear for a TPI, I had a full bolt on 92z28 and swapped from 3.23s to 3.73s car lost ET at the track. If you have a manual trans it will work fine but an auto 700r4 or the 4l60 is a no go..... as for cams I like the LPE 21/219
Comp.cams 503
Comp.cams 286hr10
No more than a 2800 stall
1-3/4 headers
58mm throttle body.
Alum.heads and 1.6 roller rockers
Sent from my LG-P999 using Tapatalk 2
Schurters LT1
Advanced Tech
Mar 18, 2004 01:11 AM
yzguy
Classic Engine Tech
Feb 11, 2004 10:33 AM
Schurters LT1
Advanced Tech
15
Feb 9, 2004 12:41 AM
kdubb
Jan 17, 2004 12:01 PM
