car wont move forward
Old May 10, 2006 | 07:49 PM
Zion's Avatar
new problem,
car idles fine and revs fine when idling, but wont move forward without heavy choking and sputtering and trying to die.
i tried to check engine codes and it wont even flash.
I just put new headers and exhaust in last night and it has been doing this since i finished.
i have checked all my wires, and everything seems fine.
all the air pump lines and cat have been removed
i have also posted this here:
http://www.thirdgen.org/techboard/te...e-forward.html
Old May 10, 2006 | 08:13 PM
LT1Formulation's Avatar
Re: car wont move forward
Do you have an air leak after your MAF somewhere? I'd be thinking it was some sort of vacuum leak. Spray some carb cleaner around your engine and if the idle changes, you've pinpointed your leak.
Old May 10, 2006 | 08:44 PM
Zion's Avatar
dont have maf, its speed density
would this still work?
Old May 11, 2006 | 08:22 AM
It's possible you still have a leak somewhere, I'd try it and see.
Old May 11, 2006 | 11:28 AM
Zion's Avatar
ok thanks
Old May 14, 2006 | 01:02 PM
Zion's Avatar
no leaks, replaced ECU, still nothing.
Old May 14, 2006 | 08:22 PM
Pneumatic_Tire's Avatar
Go back and look oever ALL connectors on the engine. Something probably didnt get plugged back in after your header install, or something got accidentally unplugged when you removed your AIR pump that shouldn't have. If this problem just started right after your header install, 98% odds say it's something simple as that.
Old May 14, 2006 | 10:25 PM
net_coma's Avatar
Exactly right...when you have been working on the car and something pops up always look at the things you have just worked on first.
Old May 15, 2006 | 02:55 AM
Zion's Avatar
kinda found the problem.
i think the wire to the o2 sensor was grounding out, it looked a little melted.
there is one other wire bundled with the o2 going to another sensor. could the other sensor cause this problem?
I replaced the o2 wire and rerouted and zap strapped it and still havingthe same issue
Old May 15, 2006 | 05:55 PM
Depends on what sensor that wire goes too. If that wire was melted too, then fix it. It can't be doing anything good being melted. Other than that, Still go over EVERHTHING with a fine tooth comb. I guarentee something you are overlooking is the culprit. Check all your vacuum lines too. They can cause MAJOR running problems. If you are unsure of how to properly route the vacuum lines, do a quick search here, or at Thirdgen.org for a vacuum hose diagram. I know how this is, lol. Good luck. You'll find it.
Old May 15, 2006 | 11:19 PM
Zion's Avatar
it was not the o2 sensor
Old May 20, 2006 | 06:45 PM
Zion's Avatar
Its wierd, i removed the cap and cleaned the connectors and it drove fine to 4000rpm then crapped out again, about 10min later it started crapping out all over the rpm range again. mostly between 2-4
Old May 21, 2006 | 11:05 AM
Dave89IROC's Avatar
check your timing, I pulled the AIR off my old car and the dist. was just loose enough to turn when I pulled the tube
Old May 21, 2006 | 03:19 PM
Zion's Avatar
yeah, ive been trying to manually adjust the timing but i cant seem to get it.
now the car wont idle and the tach dances all over the place
Old May 22, 2006 | 06:52 PM
87irocz28_383's Avatar
did u take offf the brown/beige wire to the dis when u tried timing? ..and with that idle and rmps dancing sounds like a vacum leak
