car is whinning... HELP?
Old Jan 18, 2003 | 06:14 AM
john-e-boy's Avatar
My 89 RS started whinning yesterday. The sound is coming from the back of the car, At first I thought it was a piece of plastic rubbing on the tires but when I looked there was nothing. I had a guy flash me and point to the back of the car but I don't know what he was reffering to.
My next thought was the rear end, I thought the differential sprung a leak and had no fluid and that was why it was whining, so I took it to the shop and popped the differential cover off (wow that oil stunk) and changed the fluid. There was quite a bit of fluid in there so I thought it might have been lo. I put it all back together, filled it up and test drove it, and it is still whinning.
What can this be?? a bad rear end??
John
Old Jan 18, 2003 | 05:53 PM
aklim's Avatar
What did you see when you took the cover off? Were there metal chunks? Did you do a wear pattern to see if it is sitting abnormally?
Try this. Take your Driveshaft out and check it. The U-joints should turn from one end to the other smoothly. No nochiness is acceptable. Next you need to have the DS balanced and see if that cures the problem.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
