Car runs bad, need help asap
Old Apr 28, 2003 | 12:50 PM
Narcah's Avatar
Question Car runs bad, need help asap
Car Info: 1989 Iroc Z, 5.7 TPI, 86,000 miles.
Background: Ok, so while helping to cure my need to understand how things work, I practically took my entire MAF apart. Took the screws out, pried around inside, etc etc.
Symptoms: The car idles low (600 rpms), surges (600-1800 rpms) sometimes, and will even die. This all while just trying to idle!
Symptoms: While driving, sometimes it'll act like it's dying, power drops, the 'Egine is dying' light comes on, and just plain bad stuff that makes me question it's ability to get me home!
Question: Does this sound like the MAF is dying? If so, should I get another stock one, or is there good upgraded model to get? Thanks for your help!
Old Apr 28, 2003 | 12:55 PM
IrocManiac's Avatar
Dude you killed your MAF it sounds like to me. Those things are pretty sensitive....(but for some reason I was thinking in 88 or 89 they went to speed density??? If it is the MAF you need a new one.
Old Apr 28, 2003 | 01:30 PM
RedIrocZ-28's Avatar
Happened to me one time when I forgot to plug my MAF back in. If thats not the case, sounds like you need to get a new one. And NO its not worth it to get an upgraded one. Get a factory replacement. Upgraded ones don't really do anything for you as far as I have ever heard.... well besides lighten your wallet more.
Old Apr 28, 2003 | 02:04 PM
91ReDZ's Avatar
Yea that sounds like a maf problem. What code is it throwing
Those things are very sensitive
(Gotta love speed density )
Old Apr 28, 2003 | 03:19 PM
Narcah's Avatar
Is it possible to switch my car over to Speed Density fairly cheaply? Or just go for another MAF? I have no clue what code it's throwing, it's parked, 'cause of winter weather, at my moms place so I only see/drive it a couple times a month.
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
XtremeLt1
Aug 1, 2002 11:25 AM
Brent94Z
Mar 21, 2002 04:44 PM
