Car idles rough and backfires after header install. Why?
Old Dec 8, 2003 | 10:12 AM
kbog54's Avatar
Question Car idles rough and backfires after header install. Why?
I just finished installing hedman long tube headers that are covered with header wrap and a heat coating on my '83
Z-28 with CFI. I havent put the rest of the exhaust on yet, so the headers are just open. I installed the stock o2 sensor that was in the manifold into the header collector, it's the one wire model. I had to cut the wire, and lengthen it to get it to be long enough.
After I was done with the install, I fired it up, and it idles rough, with backfires every minute or so. If I give it gas or put it into gear, it wants to die.
I was told that I might need to get a heated oxygen sensor, where could I get one, and does it matter how many wires it has?
Could putting the spark wires back on the wrong plugs have anything to do with my problem?
If you need anymore info, let me know
Old Dec 8, 2003 | 01:34 PM
aklim's Avatar
Install the rest of the system and see. I doubt that the HEGO will help much. The ECM doesn't recognize it till it gets into closed loop. A HEGO has 3 or 4 wires. I would get the 3 wired one. It has a positive, ground and feedback wire. Positive is set to a switched power source to help it heat up and the ground is for the power. The feedback goes back to the ECM like the OEM model.
Old Dec 9, 2003 | 09:48 PM
sqeezeplay's Avatar
Did you cut the O2 wire or did you cut the wiring harness and extend that? Because if you cut the O2 wire it's garbage. You can only cut and extend wiring harness you can't extend O2 wires heated or not heated.
Old Dec 9, 2003 | 09:50 PM
sqeezeplay's Avatar
It is possible you mixed up some off the spark plug wires.
Old Dec 10, 2003 | 09:56 AM
kbog54's Avatar
fixed
The o2 sensor works fine with the wire extended. The plug wires were mixed up causeing the backfire.
thanks
bfmv13trivium
Jan 14, 2015 09:57 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
thenewkid
Nov 18, 2014 12:57 PM
F(ast)-body
Feb 26, 2003 09:05 AM
