car idles at 500 RPM when its warm
Old Apr 1, 2003 | 08:00 PM
Rice Killer87's Avatar
pretty much what the topic says,what can i do to raise the RPM's up to 700 or so where they should be? its a 87 IROC w/ a TPI. thanx
Old Apr 1, 2003 | 09:23 PM
87IROC-Zowner's Avatar
I wouldn't rely on the Tachometer competely to adjust your RPM's at idle, but if your car is idling so low that it lopes, then you can do a quick adjustment to the throttle plate stop. On the driver-side of your engine, at the Throttle body, if you look from the back of the throttle body towards the front of the engine, you'll see a recessed screw on the top-driver side corner. This takes a T-20 (maybe T-15) Torx bit. Simply screw the screw clockwise (tighten) until you are happy with idle.
Old Apr 1, 2003 | 09:33 PM
StealthElephant's Avatar
my car idles about 550 when im in drive, it's perfectly smooth though.....never stalls...should it be higher? i just figured lower RPMs at a redlight means better gas milage....
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
