car hesitates...why?!?!?
Old Jan 23, 2003 | 12:46 PM
white86TA's Avatar
i have a 86 trans am, 305 carb, when i punch the gas in seconds gear around 2000 or 2500rpms, cant member the car kinda hesitates and wont climb for about 3 secs and then begins to climb again...why is that...whats wrong?
Old Jan 23, 2003 | 02:41 PM
Error404's Avatar
does it happen if you ease the gas and slowly push it further down? Does it happen in any other gear? I had a problem similer to that on my 97 GMC, turnes out the Throttle body wasn't bolted down tight enough and air was seeping through... but sence yours is carbed, I'm not sure if thats the problem.
Good luck!
Old Jan 23, 2003 | 05:24 PM
Sitting Bull's Avatar
Might be the notorious QJet bog. Your carb probably needs to have the Air Valve spring tension reduced and a richer set of secondary rods installed. Go to www.thirdgen.org and look up the Tech Article on tuning the QJet.
They work very well, and get great mileage, when tuned right
Old Jan 23, 2003 | 06:36 PM
Black6SpdTA's Avatar
Sounds like something in the carb. Happened to my Yamaha Warrior a while back. It may be an ATV but I dont think the carbs are that much different. It turned out my pilot jet had fallen out. We put a new one in and everything is good.
Old Jan 24, 2003 | 05:18 PM
BOZS89IROC's Avatar
Check your ignition timing and emmision equipt. I had the problem on my 84 Z L-69 and it all the F@#%$^& smog eq. (EGR, O2, A.I.R. sys. ETC...) once all that was up to par I still had hesitation, I adjusted my timing (6 deg. BTDC) and all was right with the world.
BOZ
Old Jan 24, 2003 | 11:35 PM
I EAT T/A's Avatar
Ahh, just give'er a good tune-up.
I EAT T/A's Avatar
I EAT T/A's Avatar
I EAT T/A's Avatar
Old Jan 24, 2003 | 11:47 PM
I EAT T/A's Avatar
I apparently replied 41 times, so I'm deleting the useless posts.
Sorry.....
I got sick of deleting, so not all of them are gone, feel free to delete the rest mods.
Old Jan 25, 2003 | 01:57 AM
90rocz's Avatar
Classic smog vacuum secondary carb bog. There are secondary lock-outs that at low rpm operation are controlled by vacuum and pull the lock-out on the secondary choke horn keeping it shut.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
