Car Broken Down!
Old Nov 21, 2003 | 01:07 AM
guyver182's Avatar
Question Car Broken Down!
MY CAR WONT START! it has a pretty brand new battery and has been kept up really really well it is a 89' camaro v8 RS and it just wont turn over. PLEASE HELP!
Old Nov 21, 2003 | 01:13 AM
krazzycowgirl's Avatar
Couple of questions for you there
when you try to start the car does it try to turn over but will not?
Or does it not want to even try to turn over?
Couple things you might want to check is: If it does not want to turn over it could be the Starter or the Alt.
Or you might also want to check to see if the Fuel pump (which is in your tank) is trying to go when you are trying to start the car. Easy way to do this is have someone stand next to the gas tank while you try to start the car if they are hearing a noise from the tank then the fuel pump should be in working order. Also Check your fuel filter its under the drivers door. it may be clogged.
Old Nov 21, 2003 | 01:19 AM
guyver182's Avatar
Post hmmmmm....
it doesnt not even try to turn over like its just dead.
Old Nov 21, 2003 | 01:23 AM
Then it could be almost anything.
Check for spark & fuel.
is the check engine light coming on?
Old Nov 21, 2003 | 01:29 AM
guyver182's Avatar
yes
yes it does say check engine light but i also has all the other lights on too.
Old Nov 21, 2003 | 11:36 AM
chevyman502bb's Avatar
i dunno if this would make sense but its worth a try.........fuses?
Old Nov 21, 2003 | 11:40 AM
hey man, i hope u dont mind me posting a ? in ur thread, heres my question......my motor came from an 87 Z, its a 4 BBL carbed 5.0...is it lb9? lo3? whats the deal?
Old Nov 21, 2003 | 12:18 PM
Garage Inc.'s Avatar
I would say check the fuses if you have a new battery, let us know man how you make out
An easy way to tell as long as it's the stock engine..
if the eighth digit (letter) in your VIN number is..
"F" = LB9
"E" = LO3
and you could also have an LG4 maybe..
"H" = LG4
Old Nov 21, 2003 | 12:20 PM
i cant use the VIN cause the motor came out of a different car, and ill be damned if im goin back to the junkyard just for some #'s
Old Nov 21, 2003 | 01:06 PM
guyver182's Avatar
Angry i hope i get it going to
IT STARTED THIS MORNING! a guy at my work said it could be the cylanoid in the started that cyndrical thing next to the engine towards the bottom. so i went to a mechanic and he says that could be it. cause the battery and evreything else in there are fairly new. so it only just doesnt start if it gets too warm...guess i should only drive to work from now on. lol. at least untill i get paid. if anyone knows what else it could be email me at voltron182@hotmail.com
Old Nov 21, 2003 | 01:33 PM
im glad she fired up man, nothin like solving a problem that leaves you stranded....lol
Old Nov 21, 2003 | 01:34 PM
LandryP's Avatar
Make sure the battory cables are clean and tight on the battery and the engine block every third gen that i've owned has given me problems like this that usauly turns out to be a bad connection. Also next time it wont crank turn the lights on and see if they are bright, if there bright you probly have a good connection, and you can try gently tapping the starter with the handle of a hammer while someone else turns the key, this can free up a sticking solenoid
Old Nov 21, 2003 | 01:51 PM
doug791's Avatar
AHHHH i cant believe i didnt think of that im retarted. Yes id almost guarantee its your solenoid. The problem in our cars is called "heat soak" The solenoid is so close to the engine and our cars run so hot that the solenoid stops functioning. Your options include....there is supposed to be a heat sheild around the starter. If there isnt one anymore (they do fall off sometimes) then you can replace it but many people say it does jack all. Your other option is to buy a remote starter solenoid which you position i "think" somewhere in your dash thirdgen.org has a tech article how to put the solenoid in. Also a real good excuse to put in a push button starter just for fun But id be willing to bet dollars to pay its the solenoid.
Old Nov 21, 2003 | 11:14 PM
guyver182's Avatar
Post EXACTLY!
that is what everyone has been telling me but i just wish it was cheaper than 160 to replace. lol. i have to get a new starter and the other thing. If anyone knows how to install it and know where to get it cheap and lives close to me PLEASE HELP MYSELF lol.
Old Nov 21, 2003 | 11:50 PM
If you could get the car out to my place I am sure my husband would help you.
Oh he asked when you want help.
