can't get steering wheel off
Old Oct 9, 2003 | 04:20 PM
Error404's Avatar
Ok, my grant steering wheel, install kit, and puller came in the mail today, but I can't get the old wheel off!
The bolts that came with the wheel puller didn't fit the holes on the steering wheel base, and I finaly got some bolts that fit (7 mm) but the threads on the inside of the wheel looks stripped, but I tried anyway and I could never get the bolts tight.
Oh, I already have the center bolt off.
Is there any way to take the wheel off with out a puller?
Old Oct 9, 2003 | 05:26 PM
kc chief's Avatar
Yes, but it's risky in my opinion. Same exact thing happened to me and a mechanic walked me through it over the phone. Grab the wheel at the 12 and 6:00 position, now the fun part, push/pull forcefully for a good 20 seconds, then grab the wheel at the 3 and 9:00 position and pull straight off. Worked for me.
Try at your own risk, I'm not responsible for any damage to the shaft.
Old Oct 9, 2003 | 06:09 PM
TheGreatJ's Avatar
Here's a method I've used in a bind, but it's another one of those "at your own risk" deals. It also requires a friend to assist.
Take the big center nut loose, but leave it on the shaft. Loosen it to where the outside is about even with the end of the shaft. Sit in the car and lean back as far as you can, grab the wheel and pull. Keep pressure on it while your friend taps the shaft with a hammer. He may need to tap hard. The nut will keep the wheel from flying off and hitting you in the face, but make sure your friend isn't pissed at you.
Old Oct 9, 2003 | 06:31 PM
Error404's Avatar
someone mentioned this method on thirdgen, I'll try it as soon as my roomate and I are both home, and we come up with a hammer.
I have a huge socket with a lug nut jammed in it, think thats heavy enough?
Old Oct 11, 2003 | 12:55 PM
Error404's Avatar
wohoo!! Finally got it! Thanks to Chris!! (cg91ta)
This is EXACTLY the look I wanted. The pedals used to look a bit out of place (being the only bright metal inside the car), now the spokes on the wheel have the same look ;D
Here are some pictures of it installed:
Old Oct 11, 2003 | 03:09 PM
TheGreatJ's Avatar
I have the same wheel, but with black spokes.....and the same pedals, but for a manual trans.
Old Oct 11, 2003 | 03:20 PM
DrDUKE's Avatar
Yeah thats an awesome wheel, Ive had it on the last 3 cars trucks Ive owned. I would put it on my camaro too, but it has an air bag and I kida wana keep it.
Old Oct 11, 2003 | 04:03 PM
Error404's Avatar
yea, I like the look of no air bag
I guess it's not to save though
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
