Can I use an LT1 starter
Old Jul 16, 2003 | 11:19 PM
IgorT.455/406's Avatar
Hey guys. Gonna put my 350 back into the car soon, but its a high compression motor, and was hard to start with the previous starter(s). So this time, I bought a solenoid relocation kit, hopefully this helps. BUT, from what I saw, my LT1 start was a mini unit, but was high torque. Can I use this starter on my 350 ('88 motor), or only if I use the T56 as well, or not at all? Thanks guys.
Old Jul 17, 2003 | 02:55 AM
cwalsh
Guest
Posts: n/a
I am using a LT-1 starter on my 89 block. I like the way it fits much better. I am pretty sure you do not need to have the 6 speed in there to use it. The nose is smaller to fit in the bellhousing but should work for the auto.
HTH
Chris
Old Jul 17, 2003 | 10:41 AM
Excellent, thank you. I figure with it, the remote start solenoid, and the starters physical smaller size, should work OK I hope. There are lots of LT1 parts I can use it seems. Can't wait to tare appart and then rebuild the LT1 itself!
warmeck
Feb 5, 2015 11:04 AM
Jason Short
Jan 19, 2015 06:34 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
