Which bilstein shocks?
Old Jul 17, 2003 | 09:13 AM
Damen's Avatar
Ok, so you all were kind enough to let me know that the stock IROC shocks (the bilsteins) are probably better than the KYBs I was going to move to, so I've decided to get new Bilsteins. The question is, which ones do I get?
I've found 2 different ones for my car:
The Bilstein Sport, and the Bilstein HD
"Chevrolet Camaro IROC/Z28/Berlinetta/RS 82-92 BILSTEIN SPORT- For the performance minded driver. Designed to push a car's suspension to its performance peak, these shocks are well suited for use with special springs, anti-sway bars or other suspension upgrades. Part# B461021 (Rear)"
"Chevrolet Camaro IROC/Z28/Berlinetta/RS 82-92 BILSTEIN HD- These shocks provide improved handling and stability without sacrificing ride comfort. As with all Bilstein shocks, these shocks instantaneously adjust to changing road conditions. Part# B461121 (Rear)"
Can someone actually EXPLAIN the differences here? I'm assuming I want the HD, since my car is stock so far, but should I get the sport if I'm planning on upgrading the suspension in the future?
Thanks guys.
Old Jul 17, 2003 | 10:43 AM
dewey316's Avatar
both kits use the exact same front strut, there is only one for the front.
the rears are diffrent, the Sport is designed for lowered cars, i don't know if the dampening rate is higher, or the valving is diffrent, i have never been able to get a straight answer from bilstein on this.
if you plan on getting lowering springs, since you are doing all the work right now, might as well just pick up a set of springs, you will be money ahead to do this now, then do it again in a few months, this way you only pay for an alignment once. if you descide to lower the car, get the sports, if you don't i say go with the HD.
Old Jul 17, 2003 | 12:29 PM
kandied91z's Avatar
i have the HD's with the car lowered and no problems........
Old Jul 17, 2003 | 12:31 PM
Damen's Avatar
So no problem with getting the HD's then. Sweet. I ordered them. Thanks much guys!
karpetcm
Dec 16, 2015 09:07 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
