Can I remove my heater core?
Old Feb 18, 2003 | 12:36 AM
newby's Avatar
My car will no longer be driven in the winter, it's going to be a summer car only. I currently have the dash off while I'm re-doing the entire enterior.
My question is, can I safely remove the heater core? My cars cooling system doesn't require it, correct?
Old Feb 18, 2003 | 01:36 AM
stevem's Avatar
that is correct just make sure that you loop the two hoses together with a flush tee or something like it.
Old Feb 18, 2003 | 10:21 AM
Blue89Bird's Avatar
you can remove it, but its really not worth it unless its not working. it really doesn't weigh to much and you have to take your entire dash apart to get to it.
Old Feb 18, 2003 | 10:53 AM
newby's Avatar
Well, I do actually have the entire dash off right now since I'm re-doing the interior.
The blower for the AC was taken out of the car, and I'm pretty sure that's the same blower that works for the heater, so it won't work anymore anyway
Old Feb 18, 2003 | 05:10 PM
82355's Avatar
No a heater core does not have anything to do with cooling your car down, GM used to offer heater delete as an option on some cars.
If your going to take the heater core out, then why bother looping the hoses together? Do away with all the heater hose, and related crap, and then just plug the hole in the waterpump and intake. It will make it a lot cleaner under the hood,
Martin
Old Feb 18, 2003 | 05:12 PM
newby's Avatar
Martin
OK, that's what I was wondering, thanks.
Old Feb 19, 2003 | 01:38 AM
stevem's Avatar
YOU HAVE TO LOOP THE HOSES OR YOUR CARS COOLING SYSTEM WILL NOT WORK PROPERLY AND MAY CAUSE OVERHEATING.I KNOW THIS.......
Old Feb 19, 2003 | 07:26 PM
TheGreatJ's Avatar
No you don't. Just drill 2 small (1/4" or so) holes in the flange around your thermostat to keep it from hydro-locking and you'll be fine. You're better off taking the hoses completely out because that way there's less stuff to leak, and it cleans the engine bay up a bit.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Boss002
Jan 20, 2016 12:17 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
ducttape1975
Jul 10, 2015 06:29 PM
