Can a 92 Gauge cluster and Steering column be put on an 82-90?
Old Apr 9, 2003 | 03:54 PM
Blown350ZZ4's Avatar
Has anyone ever put a steering column and steering wheel and a gauge cluster from a 91 or 92 on an 82 - 90? Does anyone know if everything fits and how difficult it is? Thanks
Nick
Old Apr 9, 2003 | 09:07 PM
thisoldcamaro1's Avatar
I did this. I found it easier to move the entire dash board from a 91 to my 82. The cluster looks close but it took less fabricating to move the dash. Be forwarned pre 90 is a mechanical spedo and 91 and up is an electronically driven spedo.I did it mainly because the output of the 4l60E (part of the LT1 conversion) is electronic. Also the pins dont line up, you have to rewire the harness at the gauge cluster.
I found an entire dash and cluster from a v8 rs for $200.00
The results though were terrific, the new cluster is a nice change over the old one.
Hope this helps
Bob
Old Apr 10, 2003 | 12:01 AM
Hey Bob,
Do you think it was more trouble then its worth??
Nick
Old Apr 10, 2003 | 07:24 AM
If I didnt need to go to an electronic speedo I would have left it alone. Its not hard just time consuming to get it to fit correctly. I probably took it in and out at least 4 times.
bob
mackirockz
Feb 4, 2015 07:03 AM
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
