can a 305 be a fast engine?
Re: can a 305 be a fast engine?
Takes a confident guy to admit something like that.
I didn't get a chance to read it, lots of surfing and reading about turbos to do.
What are the differences between 305/350 vortec heads? So they used 350 ones and got the best results? Were they milled down any to increase compression or what cc were they? I guess I should just read and find out. hehe BTW, I don't think any reasonable person discounts that any engine including a 305 can make decent power, it's just the effeciency (=cheap to make fast) that it does so. Plus there is a huge stereotype against them.
I don't know much about engine building, just from what I've read so I'm not the person to take advice from. But the comparing the 305/307 to a 302 is like comparing the camaro ss to the cobalt ss. They're two completely different animals. They have totally different rod/stroke ratios. The 302/327 lend themselves quite a bit better to high reving (from what I understand) because of their larger bore and shorter stroke. Nothing to shroud the valves at high r's.
Originally Posted by LagunaS3
I also know they make a stroker kit for these engines...it takes them to 331 CID. As for the displacement argument, let's remember that 67 Z28 Camaro's are 302's. It was a mixture of 327 and 283 components. So obviously with the right parts small cube motors can sure run...and many to higher RPM's than their larger counterparts.
You are right about the lack of comparison in the 327,302,305,307. They are all different. This is why GM made them. They are for different applications. The 305 and the307 were designed during the 70s and 80s, when they were in search better emissions and economy. The 302 was designed in the late 60s to be able to compete in the trans am series with the camaro. And, the 327 was put together for a bad *** motor. I don't know the exact reason why.
But, the question here is not what motor is better than the other. The question was, what can be done to the 305 for better power, and would it be worth it? My answer is use what you've got. That is if you are working on a budget. I have seen many 300 to 350 horse 305s with minimal parts and money.
If you have the money and the capability, I say get a LS1. The LS series of powerplants has to be the most impressive that GM has ever put out on the market. In my opinion.
Right, I was just stating the Laguna's comparison wasn't very accurate. Which you agree with.
Then the question comes into play. Which is more cost effective. Modding your 305 (eventually rebuilding it..?) Or just driving the 305 till it blows and save for a 350 build or building a 350 yourself.
It's all in your end goals. If you never want to make large amounts of power then just stick with a 305 a mods. If you want to surpass 350-400hp easily (<--keyword right there) then save for a larger cube motor with more room in each cylinder for better air flow and a better rod/stroke ratio.
Originally Posted by dahaus
The 305 and the 350 cranks are the same!!!! They are just balanced differently for the difference in weight of the piston!!!!!
Nobody denies that the stroked 305, or a stock stroke 305 will make less power than a 350. Thats his own choice. You don't need some crazy heads to support 400HP sorry, The heads that came on the LB9's with some work should be up to task for that really...and if he wanted more I am sure the TFS heads for the 305 would be super, or even the AL L98 heads would be sweet for it. The stock crank will be fine to over 400hp with a good balance, decent rods( factory or some cheap I beams), and a good forged lightweight piston. The excess weight than can be shaved off with a Eagle I beam, and a light piston will relieve alot of stress on that crank. With the right parts the 305 can make 400hp, can a 350 make more...yes. Can a 305 be made fast...well fast is a relative term I suppose....it may be fast to you, and not fast to someone else. To each his own, but Lynk stop being a hater.
I just looked at the specs on those TFS 305 heads. I can't wait to see some tests on them. I they are as good as I expect, then this would definately be the way to go with small bore motors. This solves all the issues with valve shrouding. I think I'm gonna start saving money.
^So do you think that the TFS 305 heads would be better than vortec 350 heads for a 305? And what about the world product torquer heads compared to the Vortech 350's and TFS 305's?
I think that both the torquers and the tfs heads should be better than the vortec 350 heads. These aftermarket heads have a combustion chamber that is designed for the 305 bore. But, the link earlier in this thread showed us an extra 20 horsepower with the vortecs over the torquers. So, I'm not sure. I guess the only test would be a comparison of all three heads on a 305. Flow numbers wouldn't be a good comparison, because the vortec heads were tested on a 4 inch bore.
I'm not sure other than the vortec head has a small chamber and maybe it doesn't interfere with the 305 bore. I have a 305 block and some vortec heads here. I think I am going to look at how they line up sometime soon.
I thought is was only the early Z/28 Camaro's that had the 302's. . .
Anyway, there was a dyno test over 10 years ago that tested stock versus 305 Torquer versus TFS Twisted Wedge heads. The TFS's made the most power despite 2.02/1.60 "shrouded" valves. Hell, the intake valve almost touches the cylinder wall.
I had an '89 Firebird Coupe with TFS Twisted Wedge heads, ZZ3 cam (208/221), Edelbrock Performer TBI intake, Edelbrock headers, etc. . . that ran 14.20 at 97 mph. Not too bad, but a short block swap over to a 350 (no other changes - same cam, heads, etc. . .) netted some 13.30's at 106 mph.
Also, the Stock Eliminator 305 TPI and carb'd Camaro's that run stock heads, intake, quadrajet/TPI, bore, stroke, compression, etc. . . are running high 11's NA. But. . . Stock Eliminator LT1 cars are running in the 10.40 range.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
