Camaro Rear Fender
Old Apr 27, 2003 | 09:30 PM
Klendathu's Avatar
Camaro Rear Fender
I have just checked at a local car parts shop and it says that they can order rear fender for my '84 Z-28, i thought that these 2 fenser were one piece that cover all the back of the car.... am i right???
Old Apr 27, 2003 | 10:23 PM
stanghunter211's Avatar
If you mean the quarter panel, which is sometimes called a rear fender, but really known as a quarter, they cut the old one off and weld the new one on......
Will
Old Apr 28, 2003 | 08:07 AM
irocz8957's Avatar
you might also want to check the junk yards for some
Old Apr 28, 2003 | 05:31 PM
Klendathu's Avatar
There are only 125$ CAN at my local Car Quest dealer so i won't get it used........
But like i said, i thought that the rear of the car was only one big piece, am i right?
Old Apr 28, 2003 | 06:33 PM
tbuck46's Avatar
The 1/4 panel from Car Quest I'm sure is not and original GM so don't expect a nice fit. While the rear looks like it is one piece, if you would strip all the paint off the roof/quarter panel area, you would see a goldish looking seam. That is where the roof and 1/4 panels are electrically brazed together from the factory. So the answer to the one piece rear end is no, it is not one piece.
Old Apr 28, 2003 | 07:38 PM
Klendathu's Avatar
Ok, but i just wanted to change both rear fender, cause both side were redone by jobbers, and they are not identical, there is one side that the fender is more larger than the other side, i just want my car to look identical for both side.
Old Apr 29, 2003 | 08:28 AM
Jim85IROC's Avatar
$125 Canadian is like what, $70 or $75 American? That's WAY too cheap for a full 1/4 panel. That sounds like it's a partial piece, which usually consists of the wheel well opening and some material around it. Most of these are known as "repair" panels and are designed to go right OVER the stock panels. They are cheap but they obviously aren't correct.
A "repair" panel is designed to replace the metal that's there, which requires that you cut out the section, weld the new piece in, then smooth the transition area over by grinding & filling.
Both types of panels require you to know what you're doing. If you're not a skilled mig welder and skilled at body work, it's going to look like a botched abortion. Just make sure you know what you're getting into.
Old Apr 29, 2003 | 10:10 PM
Klendathu's Avatar
The shop that i get my Camaro, to be restored, have a good name. It have restored the '71 Plymouth Satellite of my friend, if these bodyman are good ,surely the can repair my 1/4 panel with panel skins, and it will look like an original. Am i right???
Old Apr 29, 2003 | 11:08 PM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
If they are as good as you say, then you should be ok. But just remember, as other posters stated - it will take a skilled bodyman to weld and grind those panels on so that it looks factory.
Patricklt1
Apr 24, 2015 06:29 AM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
