borge warner 9 bolt
Old Jan 8, 2003 | 09:39 AM
ws6gta's Avatar
borge warner 9 bolt
were there 2.77 gears put in the borge warner rear disk brake 9-bolt rear ends?? or were they all 3.27
The car is an 89 camaro Iroc
Old Jan 8, 2003 | 10:47 AM
87DJP2001's Avatar
B-W 9-bolts with 2:77 gears all had Disc Brakes. There are more 2:77 then 3:27 9-bolts out there. These gears used only on 350
TPI cars.
Old Jan 8, 2003 | 11:02 AM
Scott McDonald's Avatar
I've got an 89 IROC with the 5 speed and I have a 3.45 gear in my 9 bolt. Is your car an auto or a 5 speed? If the rear end cover has never been off, there will be a tag attached to one of the bolts that will tell you the ratio in the rearend.
Old Jan 8, 2003 | 11:23 AM
87DJP2001's Avatar
The post was for gear ratios (2:77 & 3:27) used with a 350 (Auto)
engine only and not for the B-W 3:45 which came ONLY with the 305(5-sp). And they all used disc brakes.
AGAIN I WILL SAY, THE ONLY FACTORY STOCK BW 9-BOLT AXLE RATIOS USED ONLY ON 350 TPI ENGINES WITH AUTOMATICS WERE 2:77 & 3:27 (which was a option)GEARS.
Old Jan 8, 2003 | 12:37 PM
Sitting Bull's Avatar
There were also 3.70 gears for the 9 bolt.
Old Jan 9, 2003 | 12:39 PM
88 427 Camaro's Avatar
All the 9 bolt info you need is at www.9bolt.com
Miles
Old Jan 10, 2003 | 09:05 AM
ws6gta's Avatar
Thanks everyone
Old Jan 10, 2003 | 07:35 PM
camaroz28racer2's Avatar
TPI cars.
brrrrrrrrmmmmmmpppppp wrong answer, the 3.27 came on the 3.8L turbo 89 TTA also.
Old Jan 10, 2003 | 09:24 PM
87DJP2001's Avatar
BrrrrrrrrrrrrrrrrrrrIf you say so. But read the Post, the question was about a 1989 Camaro IROC. BRRRRRRRRRRRRRR
Old Jan 12, 2003 | 11:07 PM
You said only on 350 tpi cars, you didnt say within camaros
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
cmyname1
Feb 19, 2015 08:38 PM
IROC5.7TPI
Aug 19, 2002 09:58 PM
Camaro90RS
Jul 23, 2002 07:57 AM
