blow by
Old Dec 22, 2002 | 08:09 PM
citizendan1st's Avatar
blow by
hello again all.
maybe some one can help.I have an 88 305 tpi with really bad blow by...if i eplace the breather cap with a solid cap it will bloww oil out of my dipstick.
Now it just gathers in the breather and drips over..
any help would be good...
thanks again...
Old Dec 22, 2002 | 08:16 PM
TheGreatJ's Avatar
The only real cure is a ring job. Wrap a good thick rag around the bottom of the breather to soak up the oil and start savin cash for a rebuild, or get to work on that 383 in your sig. Whatever you do DON'T try to seal it up so the oil won't blow out. All that'll do is force the pressure to blow out a mainseal and then it won't even be driveable.
Old Dec 24, 2002 | 08:28 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
LOL I was hopeing someone had a tamp solution for this, I just broke a ring the other day. I moroso valve covers with the litte breather on the side and smoke billows out of there. Bought a compression tester to see which piston(s) it is and fix it but havent had the time yet.
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
