Big Plans, Need input
Old Jan 29, 2003 | 11:16 PM
CtRw's Avatar
I will soon be receiving a free, yes, free 327 from a guy I know. My thoughts were to buy a high mileage Iroc and take the 305 out and use the tpi. The reason for this is so I can make decent power and still have some gas mileage. Just a few questions to answer.
327 is bored .060 over so I will need oversized pistons
Is TPI the way to go? If so,
52mm or 58mm TBs?
Injectors?
Heads? I would have 305, 327 and 350 heads available or buy new heads?
Cam?
Exhaust I will worry about if this thing become reality!
Probably a custom chip by Ed Wright
Old Jan 30, 2003 | 08:52 PM
CtRw's Avatar
Nobody has any thoughts?!
Old Jan 30, 2003 | 09:59 PM
kandied91z's Avatar
this is such a common topic that you really should just search.
58 mm is way to high for the low horsepower your running.
it all depends on money, sure a stock tpi will work decent but rob you from power that more money would have givven you.
i'm not sure how 327's work but i would assume a ported 305 head of some sort.
i take it your getting the "block" for free and not a 327 full assembly then.
if money isn't an option go with a miniram and a accel speed density dfi to make her all run good. figure on roughly 3500 for that setup though.
you'll probably be geared more towards a stealth ram setup. good luck with it. engines are expensive and you need more than just the engine to make it work and not break parts left and right.
meissen
Jun 1, 2015 07:59 AM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
