View Poll Results: Well, which is better?
The dual-snorkel is best
14
87.50%
The open-element is the way to go
12.50%
Voters: 16. You may not vote on this poll
Which is better? Open element or dual-snorkel?
Old May 26, 2005 | 11:18 AM
  #16
iansane's Avatar
Re: Which is better? Open element or dual-snorkel?
Originally Posted by Pneumatic_Tire
Well, i could be wrong, since i never had a dual snorkel, but it appears as if it should act very similar to ram air. Cold air being forced into the air intake when driving at higher speeds. Air gets cooler the faster it moves. You know what im trying to say. I cant explain crap good in words for some reason. lol.
Ram Air is a myth.
The new setup will definately suck better air than the hot underhood stuff. go with that.
Old May 26, 2005 | 11:28 AM
  #17
Z28SORR's Avatar
Originally Posted by robvas
You want the L69 one. I don't like the looks of that one on that cardomain page
http://home.earthlink.net/~kiszka/du...procedure.html
Yah, this is definitely the one you want. Cold air and lots of it. And I believe you can still get the parts from Chevy.
Old May 26, 2005 | 02:52 PM
  #18
mako350Z28's Avatar
Unless the engine is going to draw more than 700 cfm, the TPI intake will work just fine.
A TPI 350 only draws about 540 cfm so your modified 305 will probably draw about the same.
Old May 26, 2005 | 04:07 PM
  #19
85_305's Avatar
Wowzers is that a nice looking intake
mako350Z28- The car has a 600cfm Edelbrock on it, so I am assuming that's what it will be pulling in
BTW, do you guys think that my stock air-cleaner assembly will be ok, or should I get a bigger/smaller one?
Old May 26, 2005 | 04:14 PM
  #20
Zdrrguy's Avatar
why waste the money .......the stock air cleaner does work well .......a buddy of mine did his that way .
Your flexable hosing from the air cleaner should hook right up to it .......less the sensor of course .
turn your air cleaner the same way as in the picture and it hooks up perfect !!
Old May 26, 2005 | 04:37 PM
  #21
mako350Z28's Avatar
OK, 600 cfm. Still, the TPI air intake will work just fine.
The stock air cleaner should be ok to use.
Old May 26, 2005 | 05:43 PM
  #22
85_305's Avatar
Actually what I meant was will the stock-sized air-cleaner be able to provide sufficient air-flow
Old May 26, 2005 | 05:44 PM
  #23
85_305's Avatar
Alright, thank you Mako
NewsBot
Sep 30, 2015 04:20 PM
Tarizza
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
