Better heads then Performer RPM
Old Jun 14, 2002 | 06:32 PM
IgorT.455/406's Avatar
Post Better heads then Performer RPM
Hey guys. Someone with some experience with these heads, what other cylinder heads are noticably better flowing for a resonable price. They could be Iron too, but must flow better enought that when I bolt them onto a 350 lets say, I can tell a difference from RPMs to those new ones. Thanks.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
Old Jun 14, 2002 | 06:56 PM
AutoRoc's Avatar
Post
Edelbrock Victor Jr... I've seen them for sale as low as $1180 thru magazine vendors..
215C intake, they flow 285 CFM (intake) out of the box supposedly which is good for a bit of power. I'd assume on an identically built mild street engine, the Jr's would make 30-50 more HP than the Performer RPMs. If you add a bigger camshaft, those Jr's wouldn't have a problem making 530 HP on a 350...i'd imagine a 248 duration comp cam, Vic Jr, heads and intake, .560 lift, big headers...350 cube...I'd expect at least 530 HP at 6500 RPM It'll wind man
Denny
Old Jun 14, 2002 | 09:31 PM
Post
Man, you guessed it, I got a Comp Solid Roller 280 Xtreem, it is 242/248 duration at .050, about .576 lift and 110 lsa. It is roller and solid, yeah, the Victor Juniors would make 500 HP and it would rev. I think I am going to do that. Use a Victor Junior Intake too! Maybe, its still a street car, maybe Performer RPM but not sure.
Old Jun 14, 2002 | 11:45 PM
super83Z's Avatar
Post
For a couple hundred more you could have some AFR's
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28
Superramed roller 406 10.5 compression, AFR 195's and custom cam.
future mods:
N20 waiting to be installed
Wifes new car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
Old Jun 15, 2002 | 02:17 AM
Ucantcme57's Avatar
Post
What if I told you I know where you can get great heads at unbleavible prices???? Would you jump? I did , espically if your building a 406 I was thinking 406 then I decided to get a forged crank and I went to a 422. any way. Do a lookup for Bill Mitchell Hardcore Racing Products.. In there World Products (which is the EXACT same as DART) Has a set of heads called the Motown heads, 220cc, 2.08/1.60 valves, aluminum heads, the works you can even get blended bowls and port matched in and oulets for shhh.... 780 something.. Email me if you cannot find the web page.. I will be back from vacation on the 26 of June. It's the best deal I have seen on a set of heads in forever..
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Old Jun 16, 2002 | 09:22 PM
IROCrdracer's Avatar
Post
http://web.camaross.com/bb/Forum12/HTML/014700.html
90 IROC,394 ci,vortech,Tremec TKO,9",NX 150 HP shot (just in case),Hotchkis,Spohn,roll bar,etc
my pics
IROC burnout
<A HREF="http://temp.corvetteforum.net/c5/iaz06//iroc_racey_idle_1000_rpm.mpg" TARGET=_blank>
IROC @idle </A>
my M5
Z06 hot lap
IROC dyno
IROC @ TWS
TWS II clip
IROC BHFMS clip
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
