Which is better, going to a LS1 or Lt1?
Just some more random thoughts.
a. Stock for stock, LT4's and LS1's run high 12's-low 13's- how is that ownage?
b. LT1's have limited resources, therefore are expensive to build.
c. LS1's have even more limited resources, plus the blocks can't take a lot of power- and also expensive to build.
My question is- why spend a ton of money on doing a stock, or near stock motor swap? Is it for the prestige of having something you don't currently have? Isn't the point of swapping motors to go faster?
I still stand by a carb'd SBC with any number of Aftermarket, (NON-GM) heads.
You'll go faster, spend less, and be much happier.
Originally posted by FastWhiteTA
Yes you can make all 3 of them very fast. Sounds like you have a healthy setup Aklim, what are you running in the 1/4?
That is why I ahve stated that it is too much work for too little gain.
Originally posted by aklim
Like I said, some pros have told me that fully massaged, an LT1 will make about 20HP more than an L98 that has been worked on to the same specs.
Think about it, a motor is a motor. Heads are heads. Ports are ports, etc...
If LT1's made more power than other engines with the same specs- don't you think there'd be more LT1's in the high horse, class registered race cars?
I can't agree with you more Aklim- too much work, not enough gain.
S.
What pro told you that?!?! I'd run like hell from that shop!!
S.
S.
