Best high flow cat???
hey people what do you guys consider the best high flow cat...as far as sound and performance. i want the least restrictive and highest preformance. what do u guys recomend???? magnaflow??dynatech?? catco??
Re: Best high flow cat???
don't worry about teh "high flow" thing. cats are only made by 2 companies anyway. a ton of other companies jsut rebadge them.
there is no performance gain between a 3inch $50 replacement cat adn a $130 "high flow" cat.
if you want to gain power out fo that section fo tubing, remove teh cat all together.
later
tim
later
tim
And who might those companies be? I personally know Random Technology builds their own. Been to their facility. You may be correct about the substrate inside but I do believe there are several manufacturers for the end product. I use Random Tech. and did notice a deeper, throatier sound and the car was more responsive. Random Tech also is the only company I've seen to show time and again dyno gains with their cats over an open exhaust. BTW, I do not work for Random Technology, nor am I trying to advertise for them. I just use what works and these converters work although, they are spendy, about $195.00 for each of my cats.
I bought a cheap carsound cat converter and the heat shield vibrated off, with the substrate soon following. I bought a random technology catylitic converter and the difference was like night & day on the welds and overall construction.
Like most things, you get what you pay for. I'll be ordering another Random Tech when I redo the exhaust on the T/A this spring.
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
