belt size's?!?! is it possable
Old Aug 11, 2005 | 10:42 AM
Runin2Nite's Avatar
is it possable to get rid of the ac and oxygen pump with out a delete pulley and jus throw on a smaller belt??? has any one tried this or heard of it?
Old Aug 11, 2005 | 05:40 PM
tbi92rs's Avatar
Re: belt size's?!?! is it possable
You'll need the AC pulley I know of but I didnt use the smog pump pulley, its totally unnecesary. Just get the shorter belt...cant remember the part number. I know the AC delete pulley is needed because of how its positioned. Hope it helps.
BTW< check out thirdgen.org, thats where i found the belt # for the smog delete.
Old Aug 11, 2005 | 06:52 PM
cc89formula's Avatar
http://www.thirdgen.org/newdesign/tech/serpentine.shtml
Old Aug 13, 2005 | 03:54 AM
Runin2Nite's Avatar
awsome... thanx. any one no a good place to pick up a cheap delete pulley, ive been tryin the classifeids on this and a few other boards with no luck
Old Aug 13, 2005 | 06:39 AM
PapaSmurfz28's Avatar
i got one for 30 bucks shipped...
Old Aug 14, 2005 | 11:20 AM
Damon's Avatar
I followed that article to delete the smog pump but I wanted to keep the AC. It worked fine.
There is a guy, however, who came up with a really ingenious way of deleting the AC AND the smog pump without using an idler pulley in place of the AC compressor and he wrote a thread about it over there. I think his post was in either the TBI or TPI forum on that board. Ask around or do a search and you should be able to dig it up. I recall seeing that post about a month or so ago.
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Aug 20, 2015 03:40 PM
Dams76
Aug 20, 2015 08:28 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
