beep beep-horn doesnt work
Old Sep 21, 2003 | 10:24 AM
splinter_cell's Avatar
I just bought an 84 Z a couple of weeks ago and the horn doesnt work. Any ideas what the problem is?
Old Sep 21, 2003 | 01:26 PM
aklim's Avatar
Buy bumper sticker that says "Horn Broken, Watch for Finger"
Seriously, go take a look at the horn. Hook up a test light and see if it lights up. If it does, you can remove the horn and hook it up to 12 V. If it doesn't work, replace horn. If it does, look for a bad ground. Next try the switch.
Problem with this is we have TLI. Too Little Info.
Old Sep 21, 2003 | 09:56 PM
Originally posted by aklim
[B]Buy bumper sticker that says "Horn Broken, Watch for Finger"
[B]
lol good idea.
What info do you guys need? Just tell me what you need to know and I will try my best. Where is the actual horn located anyway?
Mike
Old Sep 21, 2003 | 10:16 PM
slayer6x6's Avatar
The horn is located in the driver side fender, kind of a pita to get to. If your steering wheel is like mine, the horn button is held on by clips, it should just pop off.
Old Sep 21, 2003 | 11:09 PM
lordmetalz28's Avatar
get this my horn and rear hatch switch dont work what could taht be a fuse maybe a relay perhaps the 2 stopped working at the same time the horn and rear hatch switch
Old Sep 22, 2003 | 02:18 AM
aklim's Avatar
Could be a bad ground. Anyway, go to the GM dealership and ask them to look at their books. I'd help you but my Chilton's does not show those 2 systems in their schematics.
Old Sep 22, 2003 | 01:15 PM
Drkhrse89's Avatar
Pull the horn off and see if the wire is connected? I know that my clip that hold the horn wire (lack of technical names suck) and it no longer works.
Old Sep 23, 2003 | 01:26 AM
FishPig's Avatar
it is a 20amp fuse that is blown. I guarantee it. check your fuse box. for a yellow 20 in the horn location....
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
