BBC into 1986 Z28, Front Springs?
Old Jan 14, 2010 | 02:57 PM
OutsiderIROC-Z's Avatar
My friend is going to be putting a 454 into his 1986 Z28. What would be his best option for a set of springs to handle the extra weight that will be on the front end? The engine has an aluminum intake manifold and headers. He is looking for something close to the stock ride height in the front, maybe a bit lower but not a lot.
Thanks in advance.
Old Jan 14, 2010 | 08:05 PM
89 iroc zl1's Avatar
my dads friend built his wife a 91 with a 454 and i dont think he changed the springs and if he wants to lower it only an inch or so the extra weight will do the trick
Old Jan 19, 2010 | 10:26 AM
Thanks for the info. Did he upgrade the cooling system any at all on it? My friend is thinking of upgrading the radiator regardless.
Old Jan 19, 2010 | 05:11 PM
1988IROC-Z28's Avatar
I replaced my IROC 383 TPI struts with Lakewoods, the springs with Moroso trick springs, and the ball joints while I was at it. If his ride has over 100,000 like most third gens do he should replace them.
I also put a 3 core radiator in,Hayden cooling fan,160º thermostat. Also make sure the lower airdam is in place as that makes a big difference in cooling these cars down. (My engine temp. doesn't get above 180º even on the really hot days, and the cooler days it runs about 165-170º)
Old Feb 1, 2010 | 10:01 AM
Couple more questions:
What did y'all use for an oil pan?
Were there any clearance issues with the power steering pump and the steering box?
Thanks again for all your help, it is much appreciated.
Old Feb 1, 2010 | 12:46 PM
I have a Moroso 6qt. pan. As far as clearance issues go, there were none.
ModdedNerd
Dec 25, 2014 05:51 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
1LEThumper
Jul 14, 2003 12:45 PM
