Baker Electronics VATS bypass module: Have you used it?
Old May 4, 2006 | 09:48 AM
Rage's Avatar
I am using the VATS bypass module form Baker Electronics and my car will crank, start and sputter. Has anyone else used this module? Did it work for you? How did you wire it?
Old May 5, 2006 | 12:21 AM
89Vert's Avatar
Re: Baker Electronics VATS bypass module: Have you used it?
might be a little late now, but its very easy to burn a chip without VATS enabled, lots of places sell them on the net
Old May 5, 2006 | 10:31 AM
Zrunner90's Avatar
easiest way is to measure the ohms of the pellet in your key then insert resistors that equal it into the connector under your steering column
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
