axles on an 87 iroc 26 or 28
Old Feb 26, 2004 | 09:20 PM
lordmetalz28's Avatar
didnt all 87 and prior iroc-z come with a 26 spline axel only or did some get 28 just wanna know so i can pick out my differential an auburn heavy duty no way my mildly modded 305 can blow that.
Old Feb 26, 2004 | 09:43 PM
Black6SpdTA's Avatar
Mid 1989 was the changeover year. So your 87 will have 26 spline.
Old Feb 26, 2004 | 10:41 PM
aklim's Avatar
Get some punchuation and an Auburn Pro Series Posi and all will be well. Haven't broken mine yet. Make sure you have some sort of support for the end caps. I didn't and had cap walk so bad that on the driver side, when you install new bearings you have to clean the posi, dimple it and use some sort of sealing compound to make sure the bearing stays in place. Maybe next year I will install a Ford 9 in and solve the problem.
Old Feb 26, 2004 | 10:43 PM
mrr23's Avatar
are you assuming you have a 10 bolt? or do you know you have one? some irocs came with the 9 bolt. my friends 88 did with 2.77 gears.
Old Feb 27, 2004 | 01:26 AM
aklim's Avatar
I guess we usually assume a 10 bolt unless told otherwise. But yes, go count them and tell us.
Old Feb 27, 2004 | 02:08 AM
stanghunter211's Avatar
I believe all IROC's could be had with a 9-bolt as early as 87, I know I picked up a nice rear off an 87 iroc and its a BW 9-bolt. 88-90 saw pretty much strictly 9-bolts If I am not mistaken. 91-92 has the PBR's mounted on 10-bolts.
Will
Old Feb 27, 2004 | 02:38 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Will
Im not positive, but I think 88-89 only saw pretty stictly 9 bolts in the LB9 5 speed cars and L98s. and they werent avalible in 90
Old Feb 27, 2004 | 04:44 PM
oh its defiantley a 10 bolt has 10 bolts and the same ****ty design all 10bolts had. aklim is this ok!!!!! and aklim your talking about my caps walkin off please explain? is this the thing that a stud gridle prevents im just so lost in even buying all the parts for my rebuild
Old Feb 27, 2004 | 06:04 PM
Willie's Avatar
1987: First year for the 9-bolt in the Camaro. It was used on all 350 cars and 305 TPI/5-speed with G92.
All 1987 10-bolt Camaros had 26-spline axles. 1988 and 1989 were both transition years: More 26-spline units in 1988 and more 28-spline in 1989. The only way to know for '88 & '89 is to count.
Old Feb 27, 2004 | 09:12 PM
aklim's Avatar
Look at this cover. If you look at the center beam, it has 2 bolts. These bolts have flat ends that push down on the end caps. The end caps hold the axel bearings which in turn holds down the differential. If you make enough power and beat on it, it might cause the end caps to move around "walk" and that would be bad for the bearings. These caps with the bolts hold down the caps to prevent walk.
Old Feb 27, 2004 | 10:42 PM
aklim ,where can i find that exact same cover for my 7.5 10bolt rear
Old Feb 27, 2004 | 10:50 PM
www.ThunderRacing.com
www.TByrneMotorsports.com
It's called the TA Performance Cover/Girdle. That's what I've got. It's the same design basically as that Granatelli.
Old Feb 27, 2004 | 11:40 PM
aklim's Avatar
Here
Old Feb 27, 2004 | 11:44 PM
aklim's Avatar
I have this one
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
